Subject: Re: Slider saw fence analog/digital redouts and few other things
9/20/20
Oggie Member
Unlike my Grizzly table saw that has relatively nice magnifying glass style position indicator with visible red line gliding just a hair above the ruler, my SCM sliding saw has nothing of a kind; the rip fence itself and the movable/lockable brackets on the crosscut fence seem to be the only "aiming devices", and since there is a big gap between ruler tape and the fence/bracket edge accurate positioning becomes tedious. (See the photo below)
My eyes are still good and the hands steady, so the Grizzly style analog indicator was working good for me, especially considering speed, and 1/32" precision (red line in the middle between two adjacent 1/16 mark lines) seemed enough good for my needs.
From what I was able to dig out it looks like the digital readouts are the way to go nowadays.
I've set my eyes on Digifence(Proscale), but I haven't had a chance to see it in person.
I'm worried about the speed; I'm used at slapping/pushing my fence roughly to land near the point were I need it and than it just takes me a second or two to fix it exactly where it needs to be.
Since one sees whole ruler at once it's easy to spot desired place and go there.
That seems to me faster than watching at the single number on a display changing digits and waiting for it to show the desired value. I know it is an order or two of magnitude more precise than analog thing, but what about the operator's speed?
Do the numbers on the display change immediately to reflect the current position while moving the fence, or they need some time to "catch up" and settle once the fence has stopped? (By "immediately" I mean fast enough so that one can not notice the lag or is not bothered by it).
Any other solutions beside digital readouts?
For those of you who cut cabinet parts on sliding table: which fence do you use more - crosscut fence or rip fence?
Till now I've cut everything on ordinary table saw and I'm mentally and physically accustomed to using rip fence only, and I optimized my cut lists for that style of work.
My main reason for switching to sliding saw was scoring blade, not much other things.
Should I switch my current cutting mentality (and to what?), or just treat my sliding saw as a big table saw with a scoring blade?
Also, I was thinking of fixing some T-slot nuts (or something similar) at certain repetitive positions on the crosscut fence (like 12" for wall cabinets and 24" for base cabinets parts widths) to easily position fence brackets against those without the need to dial the brackets in every time.
By looking at the pictures does anybody knows of any available devices that would fit this fence's size and shape?
Also, any other thought or ideas are, as always, more than welcomed :)
All the best,
Oggie
9/20/20       #2: Slider saw fence analog/digital red ...
I would say it all comes down to how much you want to spend. Comparing an SCM to a Grizzly is like comparing a Porsche to a Lada. The stock fence on a SCM is fine, if you are the only one using it you will line the mark up the same all the time. If you have a bunch of employees at some point a digital readout is the way to go, if you don’t want to spend a lot of money then the pro scales are all you need. if you have some extra $$ to spend then I would go with an automatic fence, something like a Tigerstop, SCM also had a version. You plug in the dimension and the fence moves to that spot, I have seen a demo where the guy would set up a coin on edge against the fence, move it away and then back into position and the coin wouldn’t move.
9/20/20       #3: Slider saw fence analog/digital red ...
Oggie Member
Motorized fence is planed for the near future, but I have some other more urgent things to take care of before that. Most likely it will be Tigerfence.
But in the meantime, I need something to make my life a bit easier.
I'm the only user for now, but it's still tedious, because of all the lights and reflections from flat aluminum surface when looked from the above. I was thinking moving the digital readout to crosscut fence once the rip fence is replaced with Tigerfence, so it would not end up as a waste after all.
10/19/20       #4: Slider saw fence analog/digital red ...
Harold
we have been using the tiger rip fence on both our sliders for years. Our original one works with air and electricity and we have had it for 16 years. Still works like new. Our newer one is only electric and does the same job. If you do a lot of cutting, it will pay for itself in a few months in saved labor. I am attaching two photos of my older one which is still on the saw. We just received a newer model to replace it because there was a screw that had fallen off and no one noticed it and we were not getting accurate measurements. My guys found that screw under the saw in the dust, put it back on and now it is perfect again, but in meantime the new one was already shipped. I will be posting it on the machinery exchange today at 2k, pick up only in Fort Lauderdale in case anyone is interested.
A slider with computerized rip fence integrated is pretty costly, but this s a great alternative.harold
View higher quality, full size image (1280 X 958)
2/23/22       #5: Slider saw fence analog/digital red ...
Randy Duff
    • American Fabric Filter Co.
    • Sandman Products
    • The Millwork Studio
