Dust Collection
Subject: Re: VFD and Dwyer Sensors
10/5/17
cabinetmaker
Looking for help
Need to put a VFD on our 15hp and 10hp collectors
the 15hp is 12" spiral and is about 30 LF the cnc has butterfly valves for boring and or routing. Looking to put a static pressure sensor and transmitter in to tell vfd to reduce speed any ideas on model# ?
Same with 10hp it is for the edgebander
10/6/17       #2: VFD and Dwyer Sensors ...
Is your goal energy savings?
10/6/17       #3: VFD and Dwyer Sensors ...
Dylan Bayliss  Member
ITEM # 101608-33 TRANSMITTER MS-331-LCD MAGNESENSE RANGE 0-10"
regards
Dylan
10/7/17       #4: VFD and Dwyer Sensors ...
cabinetmaker
yep
10/10/17       #5: VFD and Dwyer Sensors ...
I do not believe the math will work. Have you done the annual cost of running those two collectors 8 hours a day?
10/10/17       #6: VFD and Dwyer Sensors ...
I found this neat calculator
https://www.prismengineering.com/resources/calculators
The 15 Hp cost around 1,900 per year to run based on .075 per kwh.
Then I found this caculator
http://old.weg.net/us/Products-Services/Drives/Payback-VFD-Calculator#ctrl
Usin
g the same numbers running at 70% 8 hours a day, 250 days a year saves $294 a year.
If the VFD setup cost $2,500 complete that is 102 months payback.
My number are guesses but you can plug in better numbers to get a more accurate analysis.
I'd like to see the numbers you come up with if they are different.
Good luck.
12/13/17       #7: VFD and Dwyer Sensors ...
Question: When reducing the motor speed with a VFD, doesn't the duct velocity drop? If so, isn't that a problem?
    • Air Handling Systems
    • American Fabric Filter Co.
    • Sandman Products
    • GreCon
    • J & G Machinery
      Sales of New Solid Wood and Panel Processing Machinery and Quality Used and Reconditioned Woodworking Machinery
    • Laguna Tools
