2K poly
5/7/19
Thomas
Hello,
We are having problems finding a quality 2k poly. We used Mohawk up to the point that it was discontinued. We have tried Chemcraft Verde, which did not work for us. What other companies have a quality product. What are others using with good results? Thanks
Thomas
5/7/19       #2: 2K poly ...
chris
I use Ilva products from camger coatings.
5/7/19       #3: 2K poly ...
dean c
ILVA
ICA
5/7/19       #4: 2K poly ...
Bob Niemeyer  Member
We use ICA. All kinds of choices for 2K PU
5/7/19       #5: 2K poly ...
MLC Polarion
Milesi
5/8/19       #6: 2K poly ...
CraigM
Another vote for Milesi
5/8/19       #7: 2K poly ...
Thomas
Website: http://hitefieldwoodworks.com
Thanks for the responses. Leo, we have tried Polarion or at least had a rep show it to us. One of the contributing factors for the new product will be tech support and availability,
Craig, I have not seen Milesi but have now looked at their website. They look promising. When Mohawk quit the 2k we decided not to use it and just shoot lacquers and c/v....but some products really need the 2k.
Thanks again for the help.
5/8/19       #8: 2K poly ...
Atlantic Plywood is where I get my finishes. They carry both the MLC Polarion and the Milesi 2K products. So you have a two fer if you have an Atl Ply by you.
5/8/19       #9: 2K poly ...
Brian Member
Sirca from Gemini
5/8/19       #10: 2K poly ...
mauricio poli Member
My vote is for Sirca-Gemini
Ask also for Water Based 2 K samples, it is very good.
5/8/19       #11: 2K poly ...
Kevin Member
Mind if I ask what you did not like about the verde?
5/9/19       #12: 2K poly ...
Thomas
Kevin
We could not get the verde to lay right. When mixed according to the specs, it would dry to touch in less than three minutes. We kept adjusting the mix till we were double the retarder and three times the amount suggested for reducer. Still would dry so fast that the passes would not burn in. Attempted to contact tech support numerous times and eventually learned that AkzoNobel has no tech support. So, we are still looking for a replacement.
5/9/19       #13: 2K poly ...
JaySun
MLC has an Alkyd/Acrylic hybrid product now called Coda. 10:1 mix ratio up to 4 hour pot life. Sprays good and sands well. With it being a hybrid it does have amber look.
5/9/19       #14: 2K poly ...
Bob Niemeyer  Member
Well I think almost every brand has been listed.
What you need to do is call the local or nearby Dist and have them come out and demo the products you are interested in.
All PU's are not equal, they spray different, lay down differently, feel and look different and tech support is different.
Tech support is big, both in person or somebody available by phone for questions.
PU's are a technical product.
Start making some calls and see who responds, that's where the service starts.
5/20/19       #15: 2K poly ...
Gary
I just tried a 2 part Polly from Campbell it's called Coda, I was very impressed, sprayys out real nice and looks great !
5/30/19       #16: 2K poly ...
Ed
Melisi. I’ve sprayed, Polarion, coda, Ora verde and still, Melisi is my all time favorite. Others make it easy by having one catalyst for everything, but it’s really not that difficult. This is furniture grade finish in a multitude of sheens. Interior/exterior.
5/31/19       #17: 2K poly ...
Thomas
Thanks all for the responses. Milesi is sending a rep out Tuesday morning. I hope it works out for us.
7/26/19       #18: 2K poly ...
Jeff
ML Campbell CODA is amazing! Contact your local distributor to try it out!
