Pump size
4/20/20
Al
What size air assisted pump would you recommend for spraying pigmented and clear solvent cv? We do not spray everyday maybe once every few weeks but for 2 or 3 days when we do. Currently spray hvlp compressed air with pressure pot but would like less overspray. I have an airless and I know how much faster it is over the hvlp. For kitchens and baths I like solvent base but like Kem Aqua Plus waterborne for builtins. Am hoping to get one unit to do both.
Thanks for any info
4/20/20       #2: Pump size ...
herb johnson
anything in the 15-18 to one will do either binks wagner graco or cat with a .4 gpm or greater will work, a 10-1 will also do it but for the longer run and as coatings get heavier and with the pricing being close between the two, you get more pressure capabiity as these pumps last longer than ten years and the coatings are getting heavier and heavier, this way you have something for the future
good luck
herb j.
4/20/20       #3: Pump size ...
Al
I was looking at CAT h20 unit. It says ratio is 14 to1.
4/20/20       #4: Pump size ...
herb johnson
cat unit is fine go with the bobcat gun instead of the cougar, the cougar is heavy and the bobcat gun is much lighter
good luck
herb j
4/20/20       #5: Pump size ...
Nick
You don't need a 20 to 1 to spray CV. I have a 12 to 1 Binks that l use to spray pigmented CV and a 10 to 1 Graco that I use to spray clear CV and both are more than up to the job and l spray 400 + gallons of cv per year. In the 10 plus + years l've had them l have never needed more pump then they offer to get the job done. l should also mention both are small output pumps as well, l think the outflow on both are.4 gpm. I would look into the 14 to1 Cat pump.
To make things easier on you just use the pot & gun as your dedicated WB (Kem Aqua) set-up. Doing so will save you lots of clean-up time and solvent.
4/21/20       #6: Pump size ...
JM
I have a CAT H20 with bobcat gun. Sprays CV all day every day without issue
4/22/20       #7: Pump size ...
Al
I get really good results with pressure pot, hvlp compressed air gun when spraying the Kem Aqua plus. So I think like Nick is saying have the two systems. Somethings I am wondering about. When I spray the cv and use the turntable, the side that is down always gets overspray on it. If I spray a waterborne product like Kem Aqua I don’t have this issue. I’m thinking with the aaa overspray won’t get on backside, any thoughts?
Secondly, I have read on WOODWEB a lot of guys leave thinner in their systems. I tried this in pressure pot and a few days later when I unclamped pot top the rubber gasket on lid fell off and would not stay on. Is it common practice to leave thinner in an aaa system even for extended periods?
Thank you for all of the responses
4/22/20       #8: Pump size ...
herb johnson
always leave the pump system wet with clean solvent, always
also, depending on the mfg of the pot you can purchase a lid gasket that will not swell from the solvent vapors
good luck
herb j
4/22/20       #9: Pump size ...
Al
Herb,
If you spray waterborne from aaa what would you leave in pump after cleaning it?
4/24/20       #10: Pump size ...
Brewster
Leave the pump empty after cleaning out the WB finish
4/24/20       #11: Pump size ...
herb johnson
absolutely not leave it wet, with wb, water and acetone mix or mix of water and acrastrip wb cleaner, i use acrastrip wb cleaner, never leave any pump or pot system dry
good luck
herb j
4/24/20       #12: Pump size ...
Brewster
Herb I totally disagree but I'm talking about my Kremlin AAA pumps. The pump is all SS and there only a GT seal. I shut my pumps done for the winter and never had a issue. Kremlin 15-25 and 10-18 pumps are so easy to disassemble so I usually unscrew the pump case and add a bit of Magnalube G on the seal.
4/24/20       #13: Pump size ...
Nick
I'm with Herb on this; leave the fluid lines wet.
