Sawing and Drying
Subject:
Build your own solar kiln
1/14/16
Gene Wengert-WoodDoc
Maybe you have heard of the Marc Adams School of Woodworking in Franklin, IN. They have asked me to teach week long class (May 2 - 6, 2016) on solar heated kiln drying--kiln construction, solar drying theory, etc. As part of the class, the students will build their own kiln--about 500 BF, using the Virginia Tech design. Design and construction will be such that it will be partly disassembled when you leave the class so you can take it home in a pick-up or trailer, and then you will easily re-assemble it at home.
For more info, see pages 52 and 53 of the school's catalog. The pdf link below takes a while to download...maybe 45 seconds for me.
Marc Adams School brochure
1/15/16       #3: Build your own solar kiln ...
EC Aumiller Member
Catalog would never download... went to site to find it..
http://www.marcadams.com/available-classes/unique-workshops-and-other-mediums/1866
/?query=misc0.eq.Visible&back=classes
Classes at Marc Adams
1/15/16       #4: Build your own solar kiln ...
Thanks for the faster link...the slower link includes lots of pictures for all the classes they have...that is why it is slow.
1/24/16       #5: Build your own solar kiln ...
Here is a 1/2 scale model of the kiln that my grandson (8 years) and I built this weekend.
2/2/16       #6: Build your own solar kiln ...
Correction: the capacity is 320 to 360 BF of 4/4 or 420 to 460 BF of 8/4.
2/16/16       #7: Build your own solar kiln ...
Dave Boyt  Member
Hi, Gene. Sounds interesting. I'll try to make it over there. Great photo of you & your grandson!
2/23/16       #8: Build your own solar kiln ...
Dan  Member
Dr. Gene - I plan to take this class and I like using our camper pulled behind my truck. I can't pull the camper with the tailgate down. Will the kiln materials fit, angled with the tailgate closed or should I forget the camper this trip?
2/24/16       #9: Build your own solar kiln ...
Dan  Member
Dr. Gene - no need to reply. Mark Hedin from the school contacted me. No camper this trip . I will be signing up for this class and looking forward to it.
2/25/16       #10: Build your own solar kiln ...
There will be three pieces that are about 10' long--the floor, the front wall and the back wall. Some of the 2x4 and 2x6s will be 10' long too.
2/26/16       #11: Build your own solar kiln ...
GeneWengert-WoodDoc
I forgot the roof too...it will be 10' roughly.
9/12/24       #12: Build your own solar kiln ...
Austin Member
Has anyone used PVC(vinyl) roofing membrane on the floor and walls of a solar kiln. I have tons of black rolls of it. It's really thick and 100% waterproof. My only concern is if it will trap moisture between it and the insulated cdx plywood floor.
5/31/25       #13: Build your own solar kiln ...
Daniel Member
I built a solar kiln last summer—super rewarding project! I used rigid insulation with a radiant barrier, but haven’t tried PVC membrane. My guess: could trap moisture unless you vent well. Tracking moisture and temperature was key for me. I used a simple IoT sensor setup, but now thinking of integrating data tracking through Phonexa’s reporting tools for better insights.
