Sawing and Drying
Subject:
can an electric saw mill be powered efficiently by a gas powered generator?
1/12/18
Gavin Member
Hi. there is a well considered knowledge base article examining the various considerations of electric vs gas power units for a saw mill on this site.
My question is, can an electric saw mill be powered efficiently by a gas powered generator?
Power Comparison Between Electric and Ga
1/12/18       #2: can an electric saw mill be powered ...
Gene Wengert-WoodDoc
It is interesting that the discussion in the link does not mention the use of a flywheel. Basically, a flywheel stores energy to assist with maintaining rpm and therefore power when the demand peaks, such as when first entering the log with the blade. We had a 50hp electric motor on our 60” circular mill with 2-1/2 style teeth, plus a small flywheel on the same shaft that held the saw blade.
Our John Deere tractor, model A, had a nice flywheel on it on our Iowa farm.
1/12/18       #3: can an electric saw mill be powered ...
bobjh Member
Website: http:/hardinsindustries.com
Why the need for the generator. Is the mill portable? Are you at a site that does not have electric power? I build large single phase motors. Bob
1/29/18       #4: can an electric saw mill be powered ...
Steve
The referenced discussion miss defines HP.
HP is:
A unit that is used to measure the power of engines and motors. One unit of horsepower is equal to the power needed to lift 550 pounds one foot in one second. This unit has been widely replaced by the watt in scientific usage; one horsepower is equal to 745.7 watts.
1/29/18       #5: can an electric saw mill be powered ...
The electric motor horse power has been defined as 746 watts. However, this is power OUTPUT and not power input, such as volts times amps.
