Sawing and Drying
Subject:
Drying 16/4 Walnut
3/4/18
Jaime Member
Gentlemen , I am seeking council.
I have a 16/4” Black walnut slab (44”x9’) that has been previously dried twice in a steam kiln. This was a commercial operation, so I trusted them and their experience. The first time the wood started at 46%mc finished 30-35%%mc, the second time got it down to 19-22%mc depending where I checked it. Mind you I am using a Lignomat moisture meter with prongs that only penetrate by 1/8” max. The slab severely cracked up through the slab, at that point I decided to cut it in half and run it through a wide belt sander to check the true MC. It ranges from 22%-30% MC.
I decided to make my own DIY dehumidifier kiln after doing research here. I’m ready to go but I just can’t wrap my head around a proper schedule and understanding the schedule. The closest I can come up with is T3-C2 which is for 12/4”. Also, I did a 5hr test last night and the warmest I could get it was 93*.
I have researched enough to be completly confused.. So this is where I need help as I’m not sure how to proceed and I need to get this project in motion. Your input is much appreciated..
3/4/18       #2: Drying 16/4 Walnut ...
Gene Wengert-WoodDoc
Hopefully it was well end coated, probably two coats.
Do you know for certain that it is black walnut? The slow drying makes it seem like one of the other walnuts that will take a year to dry even with heat.
3/4/18       #3: Drying 16/4 Walnut ...
Jaime Member
I don't know for sure, all the seller could tell me was it was Black Walnut. The slabs were purchased August 2016. The first kiln cycle was a year ago this month (March 2017), then the second cycle was June 2017. The ends were not coated at the time during the previous kiln cycles as I didn't know better. They are now though. I see there are quite a few different species, how should one proceed?
Jaime
3/4/18       #4: Drying 16/4 Walnut ...
I suspect, because of the slow drying and the size of the piece that it is not American black walnut. Perhaps it is tropical walnut. We tried to dry 10/4 walnut for two years, but the water did not come out until we finally cracked it. So, my experience says that you should move on to something else. I do not know how you will be able to dry this.
4/2/18       #5: Drying 16/4 Walnut ...
Allan
Website: http://www.thenaturaledgemn.com
We sell a lot of wide, thick live edge slabs, particularly walnut, but some pecan and exotics as well.
The kiln we use takes their time with pre-drying and in the kiln as well. We always coat the ends of thick woods (over 2") with tar, as well as any knotty areas. The kiln drying yield for 10/4 and even 12/4 walnut and pecan was over 90%. Yes, there's the occasional end check and some cupping, but the MC of the wood tests out at 7-8%. For the 10/4 x 36" x 8' walnut slabs, we waited almost 9 months before the wood was ready. Note: This was a commercial kiln, but it was set up modularly, i.e. 500 bd ft lots could be individually configured and run with their own schedule. I suspect most of the problem people have with drying thick slabs is that they rush things. Our business is selling slabs; paying the bank interest on a loan (to buy the lumber) is much cheaper than eating cracked wood.
