Subject: Re: Bowed Window
Bowed Window
4/2/26
Chad  Member
Website: http://www.adamsarch.com
We have a bowed picture window going through our shop currently and would like some feedback on what type of caulk other people use to glaze insulated glass into their doors or windows.
We have used a Nova Bond Pro Hybrid Sealant in the past 12 months. We have 40 pieces of glass going into this project and want to make sure I use the best product(caulk) out there to make this window last.
This window is getting painted. Would like to use silicon for the waterproofing aspects - but silicone does not hold paint. We are glazing the window from the interior of the window.
Process:
1.) We plan to lay a bead of sealant/caulk on the glass rabbet.
2.) then lay the piece of glass into the bed of sealant/caulk
3.) Push the glass into the sealant/caulk to get squeeze out on the other side.
4.) Nail the glazing stops to hold in the glass.
5.) Turn the window over after installing all the glass & glazing stop.
6.) Cut the sealant/caulk
7.) Let it dry over night
8.) Remove the dried excess sealant/caulk the next day
Thanks in advance for the feedback.
Chad
Bowed_Window_Woodweb.pdf
4/9/26       #2: Bowed Window ...
Response
I use neutral cure Dow Corning 737 in a color as close as possible to the finish paint color on insulated units in a similar method to what you describe. in steps 1-4. I prefer to leave the unit facing applied stop up and wait a day to flip and cut/remove caulk.
I would ask my insulated unit manufacturer as to what they recommend so you do not void your warrantee.
Lexel may be another option.
4/14/26       #3: Bowed Window ...
Dave Sochar Member
American Sealants Inc. (ASI): A prominent, family-owned manufacturer since 1987. They offer specialized neutral and acetoxy silicones for industrial, automotive, and construction sectors, and provide contract packaging (cartridges, tubes).
They are the folks I used. Several colors and great service. Reasonable pricing. A little oily, if I had to complain.
5/1/26       #4: Bowed Window ...
Matt Calne
The glass shop I work with uses Dymonic, and it seems to be a pretty good sealant. I normally have th install the glass, with their choice of sealant. Any squeeze outweigh let cure and cut off. Has not failed yet in 15-20 years
6/20/26       #5: Bowed Window ...
Dave Sochar Member
Chad - How is that big Bow Window coming along? You probably have it installed by now. And you are a lot smarter about pricing and managing such a project. Did you have to set glass from the outside, or could you you fit the IGU's in from the inside? Interior stops are a real puzzle.
Photos?
6/22/26       #6: Bowed Window ...
Chad  Member
Hi Dave,
The window is complete and has been installed. The project went better than I expected.
Even though i was never at the job site, I thought the window was too big. This window is massive and thought that the house would never have this big of a window in a older historic home. I am glad to say - it fit!!
We set the glass in our shop from the interior and have the stops cut for each opening. We glazed it before it was shipped to the final destination.
I am glad it all worked out on such a large monumental window.
Chad
View higher quality, full size image (2364 X 1330)
